PPBUS_G3H missing on a1932
ah! thnx for the tip.
PPBUS_G3H 1.200. Looks to be looping from 1.200 to 0.950 over and over.
3V3_G3H 0.001
Check diode mode at 3V3_G3H_RTC please.
Unfortunatelly this board doesn't have a fuse to separate PPBUS_G3H, like other models.
Is more difficult to deal with it.
Post U7000 basic voltages: P_IN, AUX_DET, SMC_RST_IN, VDDA/P, EN_MVR, AUX_OK, A/BMON.
Use proper points for test; find corresponding lines on the surrounding components.
3V3_G3H_RTC diode 0.423 (red on ground )
P_IN C7037 5.190
CHGR_AUX_DET R7016 1.289
SMC_RST_IN R6940 0.044
VDDA/P C7077 5.173
EN_MVR R6960 0.000
AUX_OK ?? NC pad?
AMON R5472 0.026 (not sure. is under a shield)
BMON TB112 0.003
Voltage with batt connected no change.
Ehm a question first to avoid stupid answers.
To read the capacitor on ohm mode. the probes on either sides off the capacitor?
R5400/10/20/30 and R5600/10 are all there. no cutting needed :)
So PPBUS_G3H doesn't go over 1.2V?
"the probes on either sides off the capacitor?"
Yes.
In fact you are measuring the sum of the 3 corresponding resistors!
R7021 309.8 ohm and on both sides 4.1v
R7022 12.0 ohm CHGR_CSIR_N 4.5v CHGR_CSI_N 5.1v
r7020 PPDCIN_G3H_CHGR_AMON 5.180v, PPDCIN_G3H 5.180v, CHGR_CSI_N 5.180v, CHGR_CSI_P 4.123v
I noticed when connect to the other usb-c port the numbers jump around more. For example r7021 jumps from 4.1v to 3.8v to 2.9v and back to 4.1v.
3V3_G3H_RTC jumps now from 3.2v to 2.0v and back
PPBUS_G3H 5.9v to 6.1v to 6.8v. with power on the other usb-c 5.3v-5.8v-6.4v
"I noticed when connect to the other usb-c port the numbers jump around more. For example r7021 jumps from 4.1 to 3.8 to 2.9 and back to 4.1."
What???
Are you checking ohm scale (and diode mode) with power on the board???
You didn't reply to my question!
"R7021 309.8 ohm
R7022 12.0 ohm"
Are these readings with power applied to the board???
If yes (I hope NOT), don't do it again.
As per schematic, BOTH mentioned resistors have 1 ohm.
2-3 ohm readings is normal then; on BOTH!
