PPBUS_G3H missing on a1932
Did you try to trigger PMU_ONOFF_L signal?
We already know that you get stable PPBUS_G3H only with battery.
What reaction do you expect on the USBC meter then?
Sorry, I need to take more time to read your answers, was about to leave when I got you're message.
I left the power cable on. I'm away for a few days, will try it out when I'm back.
Okay retry:
with batt and power connected PPBUS_G3H 11.66V
Only batt 11.66V
PMU_ONOFF_L i tried to trigger with a tweezer. one end on the pin and the other on ground. No change
Only with the batt i needed to connect the power cable shortly to get some voltage on the board.
I also measured the voltage on ppbus without the power, batt and after pushing the little power depleting button. the voltage is stil there but dropping. Now after 5 minutes still 0.264V. That should not be right?
Really matters 0.264V?
Put some logic on your job; what's the reason to check voltage without any power?
I recommend to use a switch over the power pads (with 5-10cm cables), instead of tweezers; must be sure to make good contact.
Well, the logic isn’t there yet. I can change the parts, but I don’t understand the technical part yet. That’s why I’m here and say whatever I think is usefull…
Connected the cables. Nothing happened
So you get 11.66V with battery connected, but no reaction when trigger PMU_ONOFF_L.
BTW, PMU_ONOFF_L stays high (3V), if don't touch it?
Apart of USB-C input you have problems on secondary side too.
There may be a problem with T2 chip.
Check all G3S voltages, if any appears.
PP3V3_G3S_G3H_RIO 3.286 P5VG3S_DRVH 0.023 P5VG3S_EN 0.004 P5VG3S_EN_R 0.008
The rest of the very long list of G3S voltages is 0.000
to much trouble to proceed or do you still see life in this thing?
The "very long list" of G3S voltages:
PP1V8_G3S, PP3V3_G3S, PP5V_G3S.
I didn't ask you to check ALL signals/voltages with G3S on name!
Put some logic on your job...
Is so long this thread, not easy to follow.
Post actual voltages for PPBUS_G3H, (w/ and w/o battery), 3V3_G3H_RTC and 3V3_G3H.
Is the machine recognized into DFU mode?
I can understand that :)
DFU mode not recognized.
PPBUS_G3H with batt and usb-c 11.60V.
PPBUS_G3H with usb-c power not stable 5.3-5.8-6.5V looping
3V3_G3H_RTC 3.284 3V3_G3H 3.286V (but only with usb and batt connected)
PPVDDCPU_AWAKE 0.755V
PPVDDCPUSRAM_AWAKE 0.800
PP1V1_SLPS2R 1.099V
PP1V8_SLPS2R 1.800V
