RAM upgrade MBA A1466 820-00165
Dozer
i have the 820-00165 4GB version and want it upgrade to 16gb
so i bought 4x SEC K4E6E304EE-EGCE and soldered it in
then i soldered the RAM straps like ino datasheet DDR3:SAMSUNG_16GB
CFG0: L
CFG1: H
CFG2: L
CFG3: H
that worked but coming apple and during loading 30% it is turning off
then i tryed Elpida configuration
CFG0: H
CFG1: H
CFG2: L
CFG3: H
that worked better.
starting with exteral ssd no problem, tryed to install ventura or sonoma by usb the loadbar stick in 20%
installing HieghSierra by USB is no problem but later in installation prozess it is hangin with grafical problem
the board is a known good working board
should i try another configuration or is it needfull to replace the spd in the EFI?
In the datasheet the configs for samsung, elpida, micron or hynix seems all the same (SDRAM LPDDR3-1600
need help please
tomtom67
You maybe want to get in touch with Colin (dosdude1). He has a video on YT where he did the RAM expansion, and mentioned he had to modify EFI to enable booting.
That is old 2012 Air, which Apple didn't manufacture it in 16GB configuration.
2015-17 Air machines have 16GB configuration option on the MLB.
Dozer
thanks tomtom67 from this i was inspired to try this.
the state now is i can start high sierra without problems and i can see the 16GB in the system information. the main problem still is its randomly freezing .
so my guess there is wrong timing configuration. what do you mean?
