[SOLVED] 820-00138 A1398 not switch on after short from charger, what charger does it need?
leonattpcs
Not switching on, owner says it was on until battery went flat, but now does not switch on or charge. I have a schematic for it, but no board view. Is there a board view anywhere for it? The schematic says it needs 20v, but I only have a normal 85w charger for MacBook Pro which is a lower voltage, so is there another type of MacBook Pro charger which is a higher voltage? When connecting what I have the light on it goes green then red as though it is charging so what gives?
Thanks
leonattpcs
How do I find the components on the board with no board view. There isn't a board view in the schematic either.
aprendiz
Moderator
You can find the IC because it have a number over it and the distribution of the components around it is almost the same on every board... To find PPBUS_G3H, it is on pin 23 from ISL6259 or y any component attached to teh same line.....
leonattpcs
No Title
OK I will look for it. I have found the components on the board, the black beeps the green does not. Are they types of fuse?
leonattpcs
Pin 17-18 resistance 4.4 200 ohm setting
Pin 27-28 resistance .909 on 2k setting
Pin:
2 16.6v
3 3.9v
19 5.5v
20 5.51v
1 0v
26 0v
9 4.33v
15 0.5v
All voltages little bit up and down apart from pin 19 and 15
leonattpcs
OK probably not gonna be able to as I have just found it after finding in on a 2013 MacBook Air board then found the same component on the MacBook Pro board
leonattpcs
I have looked for the same component on a MacBook Air board 820 3437 and found it, looking for the same type of thing and not found it yet so still looking.
