RedDemonic
i only get green light if i use a fresh charger that has been used with a known working board before hand. if i unplug then replug i dont get green light.
corrosion next to SMC, C6992 - 16v probably have shorted SMC_ONOFF_L.
i then cleaned the corrosion, i haven't clean the SMC. no IPA went inside the SMC.
if reflow the SMC doesn't work then i will need to replace the SMC.
PPBUS_G3H: 12.27v - should be higher - so this indicator a dead SMC
PP3V42_G3H: 3.4V
PP3V42_G3H: 3.4V
