[SOLVED]820-3476 PPBUS low no power
aurel476
no liquide damage, just customer used magsafe 45W, no power from charger and battery PP3V42_G3h present 3.41V and ppbus_g3h 0.6V tried magsafe 60w same pb already checked U7100 pin 17/18 and 27/28, smc_bc_acok 3.3v
aurel476
PPBUS_G3H 0.6V resistance to gnd on PPBUS_G3H and PPVBAT_G3H_CHGR_REG short to gnd 0 ohm short to gnd CHGR_CSO_R_N, CHGR_CSO_P_N
aurel476
short on pin 2 of F7140
51 ohm cpu coils to pin 2 of F7140
3.75 kohms PP3V3_S5 coils to pin 2 F7140
PP5V_S5 30k ohms coil to pin 2 of F7140
inject 1v to pin 2 of F7140 nothing hot
Inject voltage and monitor current. At 2 amps something must get hot. This bus is normally 12V so you can go a lot higher.
aurel476
yes find bad capacitor C7582 now another problem PP3V42_G3H 2.5V and no green/orange light, Q7010 very hot, replaced and always hot
no short to gnd pin of Q7010
aurel476
inject 3V, current 0.24a find smc hot replaced now i've green light / orange light and no fan spin not power on
PP3V42_G3H 3.42V and PPBUS_G3H 12.61v
SMC_BC_ACOK 3.39V
SMC_RESET_L 3.39V
PP3V3_SUS 3.34V
Already checked resistance SPI Bus Series Termination, next step diodmode without U6100 ?
I don't get your logic. You say this was not water damaged so why check U6100?
If this really "just" happened it would have been because of a garbage Chinese charger and 3V42 spiking or something. An issue with PPVRTC/clock chip is more likely then.
This board had a voltage spike, so many things could be dead. It could really be anything :(
You could check for power cycling on the S0 rails
aurel476
PP1V05_S0 2.7mV
PP1V5_S0 0V
PP3V3_S0 0.183V
PP5V_S0 0v
PP5V_S0_FET 0.6mV
PP3V3_S0 0.182V
no pulse no cycle :/
I do not know if it's normal to L7630, continuity 1 beep / second and stop one beep and stop loop, (without chargeur plugged of course)
