smiba
Q7706 / L7710 / Q7701 are all inactive because the system is probably not activating the backlight at all.
The system needs to "talk" to the display before it will activate the backlight, since there is no picture we can conclude the talking isn't going well
To verify this see how the BKLT_EN_R/EDP_IG_BKL_ON signal is doing. This signal is most likely low, so the backlight is not being enabled.
Since U8300's Pin 1 is LOW the display is not getting its 5V power signal, this is the issue we should look into.
How does the connector look like? Are all the pins making contact to the board?
Check if R8300 is alright
