submerged Macbook A2141 - no power on, no voltages
Sanevent
I checked the following G3S voltages:
PP5V_G3S - 0v
PP1V8_G3S - 0v
PP3V3_G3S_T - 0v
PP5VG3S_EN - 0v
PP1V8G3S_EN - 0v
PP3V3G3S_T_EN - 0v
Those are the lines that I thought were important to measure.
For the SSD lines, please tell me which ones are the important ones. There are at least 100 lines that include SSD somehow and I can't quite make up which ones could be important.
I you could tell me which G3S lines are important that I did not cover, please also let me know.
"100 lines that include SSD somehow"
All of them are power rails???
You have two SSD0/1 areas, each with 3 power rails: 0.9V, 1.8V and 2.5V (pages 87 & 92).
Sanevent
Thanks for clarifying.
I took the measurements and got:
PP0V9_SSD0/1 - 0v
PP1V8_SSD0/1 - 0v
PP2V5_NAND_SSD0/1 - 0v
So no power on that rails too.
Sanevent
When connecting the Board will it be recognized immediately or do I need to set the board into DFU mode?
As for setting the board to DFU Mode, there are 2 ways I've read about. One method uses the assembled mac and the keyboard and the other uses the Force DFU jumper. Which way is the preferred method here ?
Sanevent
ok got it. I will try the method with the switch, mentioned in the article. Is it enough for the first test to test if the DFU_STATUS line becomes 1.8v?
I only ask because gathering a second Mac will take me until next week. My colleague has the Mac from the lab for the time being.
Impossible to access DFU without 1V8_SLPS2R present.
Keep tye board alone on the desk, for test.
Do you get 3V3_G3H_RTC and PPBUS_G3H now?
BTW, F7000/1 must be soldered.
Sanevent
I measured around the U7800 and found the following voltages:
LDO_CORE 1.47v
PP0V8_SLPS2R 0v
PP3V0_G3H_RTC 0v
PP1V2_AWAKE 0v
PMU_LDO3_OUT 1.8v
I also measured the input side, because i dont know which voltages are derived from which - so maybe this is helpful.
PP1V1_SLPS2R 0v
PP3V3_G3H_RTC 3.3v
PP1V8_SLPS2R 0v
