820-00840 keyboard ant track pad not working
yair37
Yes, I was check few times? and they all look good! I also have thermal camera and put 1v but nothing also get hot
You didn't understand me :(.
You said to have 1 ohm to ground at PPBUS_G3H.
How much do you have at L7410/20/30 and L7210/20???
Many more coils on the board, but the CPU ones are the first to check.
If no other coil from the board has the same value as in PPBUS_G3H, you are lucky; check that.
You can then use voltage injection method.
yair37
check just the big coils? like L7410/20/30?
how much V can i injunct? i was injunct 1v but nothing get hot..
You can increase voltage at PPBUS_G3H, untill something gets hot.
Set amp limit to max for lab PSU.
Be sure first, no other coil has the same value to ground!!!
yair37
o.k update:
U7370 was short, replace it and now good V value, its turn on but with full fan speed Constantly no screen no keyboard activity nothing...
Post actual ohm value at L7370 and previous value, before checking U7370.
Burnt U7370 could damaged CPU, because of overvoltage...
