820-00850-A - Tries to turn on and restarts
I'm sure you can find many videos on Internat about CH341 and that 1.8V adapter.
I use different programmer anyway...
mushr00m
I just bought another 1.8v adapter and the behavior is the same itself.
It gets a bit hot on the 1.8v IC thing
But still error detecting the eprom
What could it be? The black board itself?
Do you get 1.8V at pin 8 of your chip (on the black board)?
CH431 may not recognize the chip correctly.
In such case should show some unknown ID, not all 00.
Did you test with normal SOP-8 1.8V SPI chip (without black board)?
mushr00m
There is 1.8V @ pin 8 on the black board
Its gives these images
I do not have any SOP-8 1.8V SPI chip to test without blackboard.
Since it has 1.8V on pin 8 do you think the black board is damaged?
mushr00m
Yes CH341 detects read and write an A1278 bios
image attached
Now try the same chip soldering into the black board.
Don't use the intermediate 1.8V adapter in this case.
If works, you have a problem with that adapter.
mushr00m
It worked perfectly using the black board it read and write
I put everything back and still same error.
Is there a way to buy a brand new BIOS and to program it to this computer?
I think this BIOS is trash
mushr00m
Searching for 820-0050 BIOS only results for CH341 and alike. How to find the IC on Aliexpress? U4770 also didn't return anything
U4770 has no code marked on your schematic???
Did you try searching for MX25U3235F?
Be aware to choose correct package, WSON 3x4.
sekidata
I just bought the identical setup as above for flashing T2 ROM chips. Can you recommend a MacOS app that will work as a CH341 USB Programmer?
sekidata
Thanks. Will use Bootcamp then, no problem. What's a good source for clean SoC ROM bin files? Or would you recommend reading ROMs from a known good board instead of downloading them?
