820-00850-A - Tries to turn on and restarts
mushr00m
Just check all my soldering again and the contact between the pins on the black board are matching...
Also just resolder the BIOS IC and it looks well soldered on the black board
I do not have any idea
Did you connect the 1.8V adapter correctly?
Post some pictures of your programmer and SPI chip connected.
mushr00m
Images attached below
Image 1 = everything attached and connected
Image 2 = Just disconnected the adapter and the blackboard on the position it was connected
Image 3 = The DOT on the IC is pointing to the DOT on the blackboard
did it exactly as we talked before
Seems that you've connected 1.8V green adapter in reverse way into CH341 programmer.
CH341 usually has marked the positions for 24X (EEPROM) and 25X (SPI) chips.
mushr00m
How could I attached it wrongly if since the beginning I am taking pictures and asking you if I am doing right?
mushr00m
If my connection is correct what could be wrong?
brand new BIOS IC
Many test since the beginning of this thread
mushr00m
Please
I am waiting since 10:00 in morning for your answers!
Its 14:00 I need to give it back to customers if its not solvable!
mushr00m
With another programmed it worked
I got the brand new bios and write that .BIN file you gave me.
Now what?
Solder back to the board and is it ready to work? or do I need another step?
mushr00m
After ALL of this time and procedures
I did DFU restore with the BRAND new BIOS flashed with the DUMP you gave me
And we are back to the same behavior
The only thing I think is different is that now I can click on internet recovery mode and it starts to load but then it crashs and its in a LOOP
IMAGE ATTACHED
Do you think is bad SSD? Do you think does it have grey pads below it not allowing the NAND to function properly? Would you remove the NAND and reball it?
Or give back to customer as NO SOLUTION?
  • 2023-04-17 13_48_24-2023-04-17 13_47_21-Photo - Google Photos.png ‎- Photos.png
