prodigy83
It's not stable, it goes from 1.6v and drops to .900v, then back to 1.6v, then just continues this same cycle.And C5250 voltage?
Yes, I am not finding any kind of short. I took the following measurement for voltage.5V at C5250 can be caused by shorted MOSFETs.
Did you check all above mentioned?
I went back over the mosfets, I was originally having lots of problems with Q5240 and sure enough you were right, pins 1 and 2 were shorted, I replaced this mosfet. I got the 28v on the magsafe and all is booting up! Thank you very much!I hope you've checked for short between MOSFETs pins, not to ground...
