820-2610 C7771 330uf capacitor still reading 0.3 V after replacement
plantguy123
Hello. I have a 17" 2009 Macbook Pro (logic board 820-2610 I believe). For the past few years it was having trouble starting up and then it would shut off quickly. Occasionally it would boot completely and then it would work fine for days. A few months ago it stopped starting up completely. I read on a forum about how this could be due to the infamous C7771 capacitor. I followed the heat test and put it on the radiator. The computer then booted up, so I then got a few of this capacitor: 330 uf 1362J - d
https://www.mobilesentrix.ca/capaci...3-15-17-a1278-a1286-1297-c9560-330uf-2v-b2-sm
Initially I installed the capacitor after moving the 2R2 L7770 coil to make room for it. When I was removing the original tantalum capacitor I tried moving it before it was hot enough and partially detached the + lead pad on the logic board. I tried smoothing over the *partial* break with solder. The replacement cap measured got a 0.3 volt reading with the multimeter, which obviously wasn't good.
Trying again I wanted to make sure that the capacitor was properly attached to the partially damaged pad. I tried attaching another capacitor with wires and then I hooked the negative lead wire to a screw hole (just to try something new), but got the same 0.3 V reading.
If the new cap is measuring 0.3 V, then maybe that suggests that the original problem wasn't the capacitor, or that there are more problems? I didn't test the tantalum cap because I assumed that it had been the culprit based on the symptoms.
I read on another post that the L7770 2R2 coil should be returning a 1 V reading. I got a 0.1 V reading from it - could I have broken the coil with excessive heat from the hot air rework station? Here are the photos of the repair:
Anyone have any ideas as to what could've gone wrong? Thanks.
You've probably destroyed something on the board.
That filter cap requires very short conections to its place.
Needs to have very low ESR value and Mouser has it in stock.
NEVER use hot air again in that area!
Lift one pin first, or use JBC/WELLER tweezer.
Be very carefull if you replace it with bigger size cap.
plantguy123
Thanks! Good to know about the need for short connections. Given that the 0.3 V reading was happening before I used the wires (with the cap right on the board), any ideas of where I should start testing to find the potential source of the problem?
Board looks really ugly now.
You should check all traces and solder for surrounding components of U7750.
Pay atention to Ra/Rb divider.
plantguy123
Haha yeah not looking the best.
By saying I should check the traces and solder, do you mean with the multimeter or just visually to see if everything is intact?
What's the Ra/Rb divider? Tried looking it up but can't find anything on it. Thanks.
plantguy123
Cleaned the flux off the board, and after some searching I still can't find what the Ra/Rb divider is. Would you mind explaining?
Just got some super fine multimeter probe adapters for the small chips and I'm in the process of checking the continuity of the traces in the region, will update when I'm done. So far so good.
Could the 2R2 coil have sustained some damage from taking a lot of the heat from the heat gun? What voltage should the coil itself return so I can check it? Also what should the 2R2928F63 chip at L7510 return? I chipped the corner off when I brushed it with the tweezers (visible in pics) while it was still hot from the heat gun. Did I break it?
Thanks again!
plantguy123
Thanks, makes sense.
Maybe I'll get a board for components, but in the meantime what values (voltage, resistance, etc) should I be getting from the 2R2 coil and the component at L7510?
plantguy123
So if this is the schematic info on L7510, how would I get the values I should expect from the multimeter? Haha sorry I'm a total beginner. Thank you so much!
