820-2883 no green light
Yoel Ren
Ppbus 1.3v with battery only connected
I have tried reballing smc, and i see that ball 34 is gone ( lpc_ad, but i don think it matters..)
Yoel Ren
Okay idk why, but suddenly d6905 blown, i replaced d6905, plug it original magsafe.. no green light, plugged in fake charger, and d6905 blown again..
Why did you touch SMC?
And what you did to burn D6905???
If you find a burnt piece, don't you want to find the reason, before applying power?
Now check diode mode at C6990/99.
Yoel Ren
ppvin_g3h_p3v42g3h is shorted, internal shorted because i already lift all caps and component of it, so i construct new path , you can see the picture, now it give a dim green light with blinking yellow light, i have 16.5v on fuse
Im pretty confident with my smc reballing skill.., should be no problem..
Yeah my bad about finding problem before replacing every burn thing..
Yoel Ren
Well i miss pin 6 of u6990 which doesnt give me green light.., now i have steady green light with original magsafe.., back to not seeing battery problem..
Post exact PPBUS_G3H voltage.
Also voltage and diode mode for SCL/SDA lines oif battery bus.
Yoel Ren
Okay the fan spinning but no caps lock or backlight / image or anything, and ppbus is 8.18v with magsafe only connected..
smc_reset_l 3.4v, so either isl / smc right ?
Yoel Ren
Voltage 3.4v on both, steady
Diode mode very similar 0.444 same value both
Tried another smc, ppbus is 8.2v , board still can turn on, it can see battery, but not charging and can’t run off battery
Ppbus with battery only connected is 1.3-1.4v
8.2V is not correct PPBUS_G3H (without battery).
As voltages and diode mode readings are good on battery bus, then should be SMC, or U7000 problem.
I hope you soldered ISL6258...
