820-3115 No green light -short on PPDCIN_G3H_CHGR
Hi I have an 820-3115 that had no water damage. It had no GREEN LIGHT
Power Rails were:
PP3v42_G3H 0.0V - NO SHORT
PPBUS_G3H 0.0V - NO SHORT
Found SHORT on:
PPDCIN_G3H_CHGR @ C7031 + C7030 (22UF) -top of cap read: 22 1E24
I have a donor board and replaced those caps and got rid of the SHORT
The DONOR CAPS read on top: 22 1E2N (ORIGINALS WERE 22 1E24)
Does that make a difference?
I replaced ISL6529 -U7000 with new chip. I'm now reading and I think I might have needed to replace 2 or 3 other components at the same time before giving it power?
TESTED VOLTAGE AFTER AND STILL:
PPDCIN_G3H_CHGR 0.2V - NO SHORT
Any advice going forward is much appreciated.
I didn't see the reason for changing U7000 yet.
You may have an input leakage issue, as you don't get any voltage on the board.
Check first if F6905 is good and has voltage.
Well I just realized I was getting Trolled by my power strip. It had disabled only one plug. My charger.
When I connected it with "POWER" this time I saw a GREEN LIGHT but also smoke around R6990
With freeze spray R6990 (PIN 1 =PPDCIN_G3H/ PIN 2=P18V5_DCIN_CONN_R)
looks hot right away.
Took off R6990 on the Pads I get:
Voltage: PIN 1 = 16.77V PIN2= -0.05V
DIODE MODE: PIN1= 1.97 PIN2= 0.0
I just changed the DC in board as I think it was part of the culprit too and it was. Facepalm.
If I replace R6990 I'm worried that I'll "Smoke Check" something again.
Should I be concerned with D6990?
Really strange to get short in pin 2/R6990.
In such case, (at least) lower side of D6990 is also shorted.
You must replace both R/D6990.
Do not apply power yet; you will still have short on PPVIN_G3H_P3V42G3H.
Remove C6990 and check if short went off.
If still present, change U6990.
After that check again for short at C6990/99; before applying power on the board.
Replaced R/D6990
Removed C6990 (Diode Mode on PIN1= 0.377)
Diode mode on D6990 PIN 1=0.45 - PIN 2= 1.98 PIN 3= 0.34
Not too sure if there was still a short so just replaced U6990
Added power no green light (no smoke either)
Now R6990 PIN 1=16.7 PIN 2= 16.7
U6990 VOLTAGE
PIN 4= 16.45v
PIN 3= 15v
PIN 2= 3.8v
PIN 1=1.2v
PIN 10= 3.2v
PIN 9= 3.4v (PP3V42_G3H).
PIN 8= 3.4v
PIN 7= 16.45v
PIN 6= 3.4v
D6690 Voltage
PIN 1= 0.399v (is this the problem?) PPBUS_G3H_R
PIN 2 = 16.7v
PIN 3= 16.45v
PPBUS_G3H = 0.277v @ F7040
Diode Mode 0.477 @ F7040
Thx again. this ones kicking my butt
U7000
1=6.7v
2=2.34v
3=3.9v
4=l.4v
5=0.005v
6=3.4v
7=0.0v
8=0.026v
9=0.002v
10=3.4v
11=3.4v
12=3.4v
13=3.4v
15=0.068v
16=1.19v
17=5.57v
18=5.5v
19=2.34v
20=2.33v
21=0.0v
22=GND
23=2.9v
24=2.2v
25=4.8v
27=2.8v
28=3.0v
ohm resistance 17/18= 3.7
27/28 resistance started at 3.7 but kept going up and up and up past 7.0
Replaced R7005
Now U7000 PIN 2= 16.7
Don't see the second Resistor. Can it come off of any PIN of D7005?
Stiil no green light.
Bravo for finding everything that's wrong though.
"second Resistor"
Nobody talks about such resistor.
You now have correct DCIN at U7000; didn't check PPBUS_G3H voltage?
oh Sorry "At least one of R/D7005 is bad (open), maybe both." I thought meant there were two resistors to look at. What did you mean by both? I know that D7005 now has 16.7 on all PINS. Going to the shop now and will check PPBUS_G3H. Thank you
Thank you.
PPBUS_G3H is 12.7v @ F7040 @ R6905
PP3V42_G3H is 3.4v @ C6999
I'm new at where to test so sorry if there is no structure as to where I'm testing.
No Green light still.
Board doesn't turn on?
For green light issue, post U6900 voltages.
Check continuity from pin 5 of U6900 to central pin of Magsafe (DCIN board).
Reading have changed on U7000
1=6.7v Now= 0.003v
2=2.34v Now=16.7v (obviously)
3=3.9v
4=l.4v Now=3.4v
5=0.005v Now=1.18v
6=3.4v
7=0.0v Now=0.85v
8=0.026v Now=2.0v
9=0.002v Now=
Oh wow I see U7000 heating up real fast. Going to replace again and see if that's the issue.
U6900 voltage:
PIN 1 = 0.049v
PIN 2 = GND
PIN 3 = 0.0v
PIN 4 = -0.042v
PIN 5 = -0.003v
Question? What does it mean when you get a (-) negative voltage. Is it just that those pins 4 and 5 aren't power rails?
Just in case here is:
U6990 voltage:
Pin 1 = 1.2v
Pin 2= 3.8v
Pin 3=15.5v
Pin 4= 16.52
Pin 5= 0.0v
Pin 6= 0.010v
Pin 7= 16.54v
Pin 8 = 3.88v
Pin 9 = 0.010v
Pin 10 = 0.0v
Continuity good Pin 5 of U6900 to Central Pin DC IN board
U7000 does heat up rather quickly under freeze spray like in 2 seconds. Just FYI
(edited because I took readings from U6990 instead of U6900)
You cannot have green light, if no 3V42_G3H present and also SMC_BC_ACOK.
I don't understand how do you work.
"PPBUS_G3H is 12.7v @ F7040 @ R6905
P3V42_G3H is 3.4v @ C6999"
What did you do, to lose these voltages???
