Did a reading on U7200 after looking though forum. Not sure if this will help.
Pins 1-12 = 0.0v
Pin 16 = 12.42v
Just one more note. At some point during this repair the green light went on and then I saw smoke from R6990. I replaced bad caps and R6990 and everything else you helped me with. Not sure if that would burn out a trace but just thought I'd mention it.
THANK YOU THANK YOU THANK YOU. I've learned so much. I promise to study this thread so that I can understand why you directed me in the order you did. Should I post SOLVED since you did find that is was the SMC?
