820-3115 not recognizing screen
AXG voltage only comes up under heavy graphics load.
As you have working board, compare readings between both boards.
LVDS clock signal comes from PCH; you should change it.
Did you comàre diode mode to ground readings between the boards?
Chuck60
Ok both boards measurements are equal in diode mode and ohms. Let’s say I was gonna attempt a pch swap what size solder balls would I use ?
Chuck60
Oh I’m using a bga stencil Or what I think is a bga stencil that just lines up. I will look for the Correct stencil and right down the size or just use solder paste :) thanks
piernov
Moderator
Balls should be 0.3mm. Ball size should indeed be marked on the stencil, you can't use a random stencil, only stencil for 6/7 series mobile chipset will line up.
If you have a decent BGA rework station you can buy pre-balled PCH and solder it lead-free. Will save your time and sanity.
Chuck60
Hi, I just wanted to recap. I wanted to find the exact reason why I wasn’t getting all my signals for lvds. I’m not sure this is correct but on pin 458 of u1800 I have a dead 0.00v short I removed (R2465, R2460, C2465,C2466,C7781,u7800) on this line and on u7800 Pin 1 (PP1V05_S0_PCH_VCCADPLL)
I still have a dead short. I’m guessing it’s directly from PCH. So I’ll go ahead and replace :) thank you 2informatico and piernov
Chuck60
Hi, @piernov thank you for you help :( honestly I’m gonna Use a modified digital cook top So I’m guessing it’s not classified as “decent” and I have a hozan bga hot air from the top. I also have a Quick 861On my desk. I see you’ve already answered my question About buying a new PCH above so I’ll buy it new :) Let’s see how this goes wish me luck that I’ll pull out a miracle
