I have an 820-4924 that was liquid damaged the computer will run both off the charger and the battery just fine. When you plug in the charger with the battery plugged in it will never give a green light. with the battery unplugged it will randomly get a green light after a few times of unplugging and re-plugging. with the battery in dc in is at 2.2 volts on the fuse. with the battery out dc in ranges from 3v to .3v then will just spike to 16.5 after the green light comes on. if the battery is connected after the green light is on the charger the battery will charge just fine till full and will stay charging unless unplugged. then after re-plugging it in it will again fail to get a green light. I have no clue where to start with this because of the seemingly complete randomness.
