briancomputerdoctor
You can't get K/M ohm values in diode mode.
Multimeter will show "V" when switched to diode mode.
However, do not post the "V" for diode mode readings; avoid misunderstoods.
Ah, okay. My mistake. I'll send the correct readings.
One USB port is damaged.
You should compare (proper) diode mode readings between both ports (on the same pins).
Could you elaborate on this, please.
