Macbook A1706 820-00239 Amp Meter Reboot
Instafixx
Hello,
So this macbook came with one port rebooting the amp meter.
One port stuck at 5V and other were normal at 20V.
Checked the board.
Corrosion at U3100 and the corresponding charging port.
Replaced the charging port so now all 4 ports drawing 20V.
How to confirm whether U3100 need to be replaced?
Does it charge the battery?
Which voltages do you get on the MLB?
Any reaction pressing power button?
Use 61/87W charger for tests.
Try SMC bypass, just in case.
Instafixx
So without a battery it turns on. But when i connect the battery its not doing anything. Not charging the battery.
I am uing 96W charger.
Should i just leave it on charge for a few hours and see if the battery picks up charge or do we need to replace the battery.
Instafixx
Have another case. Same Model .
Works off a charger but not when connected the battery. Tried a SMC Bypass as well.
Any history available?
Check ohm resistance over C7020/23.
What is PPBUS_G3H voltage with both charger and battery connected?
I said to check resistance (ohm scale).
R7020 + R7021 + R7022 -> 2 ohm aprox over C7023.
Same applies for C7020.
Check mentioned resistors for correct values (1 ohm).
Instafixx
We have a problem now. I put the board back on and plugged in the charger to check the voltages and suddenly the machine wont turn on now and only the right fan will spin at max continuously and then will stop.
PPBUS_G3H is at 13V
After a few tries it turned on without the battery. But still only 1 fan is spinning at max.
But its turning on like before only off the charger.
INSTALLED ANOTHER WORKING BOARD ON THE CHASIS. BOTH FAN SPIN AND THE BATTERY WORKS TOO. PROBLEM FROM THE CUSTOMER'S BOARD ONLY.
