Macbook A1989 820-00850-A No boot
Then you have a problem on USB-C areas related with the other chips.
Compare diode mode readings around these with UB400.
I hope UB400 doesn't get 1V1 LDO when you connect charger to another port...
That Macbook got wet very badly , It seems to be a layer issue, cause i can feel when i place the probe to run test around the area of U3200 if i press the area, around feels like a sponge like its bouncing back and forth , I think that i will just hand it back to the customer. I have fixed a good bit of those with that same issue and never had to face that kinda issue before .
