820-00165 orange light, no power
Looks like your lucky day; should be just a shorted cap.
If you are sure about coils measurments, then is safe to inject voltage on PPBUS_G3H.
Start with 1V, as you have a pure short practically (0.3 ohm).
You will need powerfull lab power supply; more than 10A required at 1V maybe.
JosephClampett
Well darn; I don't have a lab power supply. Although as for the coils, can you make sure I'm sure, so to speak:
- Put red on pin 1 of each, black on ground
- On some of the coils, it took about 10 seconds or so for the reading to stabilize
Is there any other way to find it?
Connect always red probe to ground, no matter diode mode, or ohm scale.
Coil values are far away of short in your case.
JosephClampett
So red probe to ground for resistance mode, continuity mode, and diode mode, and black to ground for voltage modes? And is there a way I can find the capacitor without a power supply?
I just posted one day ago; do not read only your threads...
