A2289 - 820-01987 5V
mushr00m
But considering that I only have the screen and fan connected, and the board itself matches the diode mode readings as shown in Openboarddata, why would the microphone be causing an issue?
I understand that if the microphone were connected to the board, it could potentially cause a short. However, since it's not connected and the board still isn't receiving voltage, what are your thoughts on this?
Additionally, could you provide more comprehensive explanations? I've been working on this board for nearly a month now, and it's been extremely costly both in terms of money and time, yet I still haven't resolved the issue.
mushr00m
Yes with the microphone connected PP1V8_G3S is in short.
So since I am not going to make it connected and still no short and 0V on this line.
What to do?
If 1V8G3S_EN is present (and no output short), then 1V8_G3S must come on.
If not, bad U8220 (or its solders).
mushr00m
Replaced U8220 and now we do have 1V8_G3S
Just put the board in the case again only screen and fan connected
Now we have a different behavior
20.37V on the amp meter and we do not have fan spinning any more when pluggin the charger.
It doesn't happen nothing
Still we do have 1V8_G3S ;)
What now?
mushr00m
Put in DFU mode however trying to revive I do get this message.
Actually what is most important for the customer is the data inside this computer. What to do now?
mushr00m
With the trackpad connected
I did t he revive and arrived at this screen on Apple Configurator.
However nothing happened on the faulty Mac.
What should I do?
mushr00m
By the way I am only using the cable in the faulty mac
If I put cable and another cable as a charger... ti doesnt go to this lock screen and gives me this message
mushr00m
Do I need to connect the battery?
You asked if I connected the trackpad. But not sure if you have reading issues.
I told you before that I was only connected with
FAN
SCREEN
So trackpad is not connected.... the shorted mic is not connected and anything else that is not FAN and SCREEN
Now I am doing this operation with
FAN
SCREEN
TRACKPAD
Please again, be compreehensive with you information for me to fix this machine. We are here for almost a month
mushr00m
BTW
Tried DFU forcing with battery connected and it doesnt go
Only gives the message
CANNOT USE THUNDERBOLT ACCESSORY
Still I am using the SAME ORIGINAL CABLE
If you was able to complerte DFU revive, data may be recovered into DFU mode; by an aurhorized Apple workshop!
mushr00m
Me as a technician cannot be able to recover his data?
So why are we still working to repair on these machines?
Doesn't make any sense anymore.
I spent a whole month here back and forth with you to arrive at this???
Seriously?
mushr00m
What would do to customer
Erase everything?
Turn it on?
Deliver it without wifi since this wifi IC doesnt exist on aliexpress?
How about microfone?
Please keep in mind i made 4 questions for you!!
